[mapguide-users] Fusion right click menu
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jun 27 18:57:03 PDT 2012
Really, it should be exposed as an option. I'm still a bit stumped as to why you'd want to disable that though - does it interfere with something else?
Sent from my iPhone
On 2012-06-27, at 10:51 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> If it's really that important to disable the context menu when select is
> active, then just undo the changes here:
> http://trac.osgeo.org/fusion/changeset/2460
> Or as a proper fix we should expose a SuppressContextMenu extension property
> to control this behaviour.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-right-click-menu-tp4984285p4984412.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
