[mapguide-users] Translate fusion template tabs in FR
Berg, Leandros van den [FGSBV] L.vdBerg at fugro.nl
Fri Mar 2 04:29:26 EST 2012
Hi Iulia,
You also need to copy the file 'MapGuide\Web\www\localized\en' to 'fr',
otherwise it defaults to 'en' when it can't be found. To force MapGuide
to use 'fr', add '&locale=fr' to your url. If there are still some
strings not translated, check your application definition and/or your
template file. Don't forget to restart the web server or application
pool when you made changes to the files.
Kind regards,
Leandros
