AW: AW: [mapguide-users] Changed shape columns cause problems
David Das Neves neves at systemtechnik.net
Tue Mar 13 03:23:55 EDT 2012
Sure I did ;)
I debugged now the javascript for inserting the propertypane and found the error:
{"Error":{"Message":"An exception occurred in FDO component.
The property 'BEZEICHNUN' was not found. ","StackTrace":"- MgFeatureServiceHandler.ProcessOperation line 83 file c:\\builds\\mg22win32\\mgdev\\server\\src\\services\\feature\\FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 109 file c:\\builds\\mg22win32\\mgdev\\server\\src\\services\\feature\\OpSelectFeatures.cpp
- MgServerFeatureService.SelectFeatures line 433 file c:\\builds\\mg22win32\\mgdev\\server\\src\\services\\feature\\ServerFeatureService.cpp
- MgServerSelectFeatures.SelectFeatures line 266 file c:\\builds\\mg22win32\\mgdev\\server\\src\\services\\feature\\ServerSelectFeatures.cpp
Found this string in a responsestring which somehow never got visible to me.
I was wondering a little and then I recognized that the column "BEZEICHNUN" does not even belong to this layer. Neither the new or old layer.
So I went back in the maestro and looked in the UI "Layer Properties Visible In Viewer" - all correct as proved before and cache has been purged a lot of times and also the shape and the feature class were reset many times.
Afterwards i proved the xml-content of this layer... The PropertyMappings were nearly all wrong but that was not really a wonder - they belonged all to a total different layer which was never in touch with this action.
To get this layer repaired i created a new one - selected the shape - selected the correct shape class - edited the xml - and copied the PropertyMappings to the damaged layer overwriting the existing and ... now it works.
So I got 2 points to complain here:
- Why does the Maestro not update the PropertyMappings?
- Why on hell does the Maestro insert PropertyMappings from a total different Layer?
Greetings
David
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jackie Ng
Gesendet: Dienstag, 13. März 2012 03:07
An: mapguide-users at lists.osgeo.org
Betreff: Re: AW: [mapguide-users] Changed shape columns cause problems
Did you actually *tick* the properties you want displayed in the Layer Definition editor?
Nothing ticked = nothing shown
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changed-shape-columns-cause-problems-tp4569463p4572516.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
