[mapguide-users] Re: accessing REST server
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Mar 21 08:19:55 EDT 2012
I should mention that I can also get at their data usig ArcMap or an
ArcGIS addon for AutoCAD....but I don't suppose there's a way to get
ArcGIS Server data right into Mapguide....
On 12/03/21 9:04 AM, Andrew DeMerchant wrote:
> Right - it's still in beta, so maybe they'll add some other
> standards...but right now, no such luck.
> I've had success in getting these layers to show up in Quantum GIS,
> which I'm assuming is using that reader/writer. To get the data in
> there, I just create a new vector layer and paste in the url for the
> path. When it comes in, it names the layer OGRGeoJSON. I'm sure that
> what's happening is it's downloading the json and then rendering that,
> rather than streaming it. I could live with that in Mapguide, if I had
> to...most of the data is pretty static.
> I've tried the OGR FDO in Maestro, but no success yet. I've tried
> setting the datasource value to my url - no luck. I've tried adding
> the url as my resource data file...no luck.
> I'd like to do this without the need for extra coding, so unless
> there's an FDO that can handle this, or some way to trick one of them
> into working, I'll have to wait and see if they get other formats later.
> Andrew
> On 12/03/21 3:01 AM, Jason Birch wrote:
>> It's a public provincial government server and they're providing a
>> proprietary REST format, but not open standard WMS or WFS when it's
>> fully supported by the server software they're using?  Yikes.
>> I've never tried this myself, but if you don't need live data in your
>> MapGuide server and have access to FME, you may be able to import it
>> using their ESRIJSON reader/writer:
>> http://docs.safe.com/fme/reader_writerPDF/esrijson.pdf
>> Jason
>> On 20 March 2012 12:56, Andrew DeMerchant wrote:
>>     That's the idea, yes. But it's not my server that's outputting
>>     that Rest data, so I don't have the option of WMS or WFS...since
>>     the ArcGIS server's not my server, I've got to work with what
>>     they provide. Is there any way to get json data into Mapguide? Is
>>     there an FDO that would do that? If I needed to use Fusion, I
>>     would...
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> GEMTEC Limited <http://www.gemtec.ca/>
> *Andrew DeMerchant*
> tel: 506.453.1025  /  toll-free: 1.877.243.6832
> fax: 506.453.9470
*Andrew DeMerchant*
fax: 506.453.9470
Skipped content of type multipart/related
