SV: [mapguide-users] Re: adding a points layer from ODBC problem
Jackie Ng jumpinjackie at gmail.com
Mon Mar 26 22:45:05 EDT 2012
Try previewing your data through FDO Toolbox
(http://fdotoolbox.googlecode.com). Use the same configuration document if
applicable. If you get the same error, then we're looking at a problem
either in the provider itself or in the configuration document.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/adding-a-points-layer-from-ODBC-problem-tp4182772p4659174.html
