[mapguide-users] ECWs using MGOS 2.4
Zac Spitzer zac.spitzer at gmail.com
Wed May 9 20:29:52 EDT 2012
I'm not sure, but do you even have a license to use ECW support?
the next build of 2.4 should include GDAL 1.9 support
On Thu, May 10, 2012 at 7:53 AM, Steve G <stevenlgolden at gmail.com> wrote:
> Just wondering if the same configurations are true for MGOS 2.4 as the case
> was for 2.2 to view ECWs through the GDAL provider?  I believe the current
> GDAL provider is 1.7 but not sure if that meant any changes to the required
> libraries:
> http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
> Can anyone confirm that their ECWs are visible with MGOS 2.4?  Also, can
> someone confirm the configuration as the instruction for 2.2 differed
> slightly from 2.1?
> http://trac.osgeo.org/mapguide/wiki/MGOS21GdalProvider
> Specifically the files following files were not described in the MGOS2.2
> provider:
> NCScnet.dll
> NCSEcw.dll
> NCSEcwC.dll
> NCSUtil.dll
> Thanks,
> Steve
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ECWs-using-MGOS-2-4-tp4964158.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
