[mapguide-users] Error on insert features into SQL Server Spatial
Jackie Ng jumpinjackie at gmail.com
Fri Nov 9 01:31:56 PST 2012
Okay, SQL Server inserts should work now if you use the SQL Server provider
from the FDO 3.7 final release.
But transaction rollback is still broken if you do
MgFeatureService::UpdateFeatures with useTransaction = true and an exception
happens in post-insert processing. This is where the old SQL Server provider
blew up and left you with an internally dangling transaction that cannot be
accessed.
If you require transactions, try using the overload of UpdateFeatures that
takes a MgTransaction instead. If any exceptions are thrown in post-insert
processing (shouldn't happen after 2.4, but just in case), the transaction
object is still available for you to manually roll back.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-on-insert-features-into-SQL-Server-Spatial-tp4987600p5015080.html
