[mapguide-users] .NET SDF Loader
Jackie Ng jumpinjackie at gmail.com
Wed Nov 14 18:22:59 PST 2012
If you are just trying to *load* these SDF files, and not do things like
conversion/generalization then Maestro should be able to execute your
existing Load Procedures as-is.
Failing that, you should consider using aliases instead
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/NET-SDF-Loader-tp5016355p5016459.html
