[mapguide-users] Getting error "Geometry Conversion error" when doing SpatialFilter in MgCurvePolygon
Rahul Gupta rahul.guptamcakiet at gmail.com
Wed Nov 14 22:18:14 PST 2012
<http://osgeo-org.1560.n6.nabble.com/file/n5016476/emgIssue.bmp>
isn't it for curve storage in sql spatial?.let me once again explain my
issue.  in our case sql stores parcel information.
1.User creates a circle on the map using tool given on the mapviewer
2.Internally i create 2 arcs By MgArcSegment and then merge it into a
MgCurveSegmentCollection than  create MgCurveRing and than create
MgCurvePolygon circle and put it on separate.
3.Now the requirement is to find out which parcels come within the circle
i have been able to do this when user creates a polygon or rectangle but
when using circle i get the error.
*once again i want to say, this (Creating a polygon or rectangle  or
MgCurvePolygon ) is i am doing in mapguide and  not storing in sql server .*
Rahul Gupta
View this message in context: http://osgeo-org.1560.n6.nabble.com/Getting-error-Geometry-Conversion-error-when-doing-SpatialFilter-in-MgCurvePolygon-tp5014745p5016476.html
