[mapguide-users] ODBC Schemas
Crispin_at_Linknode crispin.hoult at linknode.co.uk
Wed Nov 28 12:21:06 PST 2012
I am using Maestro 5b5 to try and configure the configuration document to a
SQLServer database view with decimal(18,0) columns containing map eastings
and northings.  And not doing very well.
If it makes any difference I am connecting to an ODBC connection using a
'Raw Connection String' eg:
 DSN=MYDSNName;Uid=MyName;Pwd=MyPwd
When I click the 'Reset' button on the feature source editor the list of
classes that contain things I am interested in is presented and I select the
classes I want to expose and configure the geometry for.  All OK so far.
However, after the "Configuration Document Has Been Reset" message if I
click the 'Edit Configuration Document' button my config document appears
empty and if I click 'Edit Schema' the message is "Feature Source Has No
Schemas".
So what happened to the resetting of the config document?  Is this a bug?
  Crispin
View this message in context: http://osgeo-org.1560.n6.nabble.com/ODBC-Schemas-tp5019402.html
