[mapguide-users] An exception occurred in DB XML component. Error: Document not found
Gabriele Monfardini gabrimonfa at gmail.com
Fri Nov 30 07:16:35 PST 2012
the space in "Web Layouts" may be the issue.
Try substituting it with an underscore
Regards,
Gabriele Monfardini
Vivi come se dovessi morire domani, impara come se dovessi vivere per sempre
Mahatma Gandhi
On Fri, Nov 30, 2012 at 3:40 PM, StuartSteel
<stuart.steel at atkinsglobal.com>wrote:
> Jackie,
> I'm seeing this on 64bit OpenSource version 2.4.0.7096. In IM Studio 2013
> the definition appears to delete, but reappears upon refreshing the site,
> whilst in Maestro 5b4 the following message appears in the UI and in the
> error log:
> Error: Document not found: Library://ab2/Web Layouts/ab2_TB.WebLayout
> The resource can be opened up, edited and saved just fine, and then after
> re-saving can be deleted normally.
> The server is running 2008 R2.
> Cheers,
> Stuart
> http://osgeo-org.1560.n6.nabble.com/An-exception-occurred-in-DB-XML-component-Error-Document-not-found-tp4183873p5019886.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121130/baecf507/attachment.html>
