[mapguide-users] ZoomToView
GordonL gordon.luckett at arrowgeomatics.com
Mon Sep 10 20:29:20 PDT 2012
Since you are using the AJAX version its a little harder to zoom in on load
since there is not a URL Parameter like the Fusion site (extent=)
So you will have to do a little work:
1. First catch the X and Y you are passing for example X=-115.443&Y=45.8789
2. Then set up EVENT HOOKING to call your zoomtoview when
OnMapInitialized()(http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking)
The zoom to view can be called once the map is finished loading...
gordon
View this message in context: http://osgeo-org.1560.n6.nabble.com/ZoomToView-tp4999411p5000965.html
