[mapguide-users] Pathing revisited
Zac Spitzer zac.spitzer at gmail.com
Mon Sep 17 19:22:18 PDT 2012
check you webserver logs, a 404 file not found will be logged in the error log
which will tell you the missing path your current configuration is referencing
On Tue, Sep 18, 2012 at 11:45 AM, Jamo <adam.jamison at portbris.com.au> wrote:
> couple of things to check.
> 1. can you connect to mapguide using maestro.
> 2. are you using iis or apache?
>   2a. if apache perhasp your directories are case sensative ensure
> "MapGuide" is actually not "mapguide"
>   2b. if iis the port won't be required so just
> http://mapguide/test_07/hello.htm
> 3. is the apache service started in services.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Pathing-revisited-tp5002498p5002499.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
