[mapguide-users] Mapgiude OS Mobile Viewer
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Tue Apr 2 13:16:32 PDT 2013
Hi.
Capture photo, coordinate, add some attributes and save everything to server over web site is not hard while you are online!
Actualy we are doing exactly that whit this application.
But offline mode is not so easy to implement.
Theoreticaly offline mode can be done with HTML5 and local store, but there are other problems using this aproach (limited size of local store, where to store photo, synhronization, local cache of map images for use in offline mode, ... ).
I think (personaly) that beter way is native (or hybrid - PhoneGAP - Cordova) mobile application (for IOS, Android, Windows, ...), because there you have everyting under control.
From: BradM [via OSGeo.org] [mailto:ml-node+s1560n5044111h3 at n6.nabble.com]
Sent: Tuesday, April 02, 2013 7:14 PM
To: Srečko Lipovšek
Subject: Re: Mapgiude OS Mobile Viewer
Would it be easy to capture a photo, a coordinate and about 10 attributes and attribute values using the mobile app?    Also, if it is not possible to be connected to the internet when capturing the data,  is it possible to create a form and store the data on the mobile device until a connection is possible? When the connection is possible, the data could then be uploaded to SQL server... Is that functionality possible?
thanks
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Mapgiude-OS-Mobile-Viewer-tp4941633p5044111.html
To unsubscribe from Mapgiude OS Mobile Viewer, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4941633&code=c3JlY2tvLmxpcG92c2VrQGthbGlvcGEuc2l8NDk0MTYzM3w4NDkwMzc2MTc=>.
NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Mapgiude-OS-Mobile-Viewer-tp4941633p5044134.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130402/af5095d3/attachment.html>
