[mapguide-users] reading and editing SDF data with java
cremebrulee mazda327 at mailinator.com
Fri Apr 12 12:29:08 PDT 2013
Thanks Jackie.
I will be just performing CRUD on the feature attributes so will further
research on this Java API. Now, you mentioned that  MapGuide Open Source 2.5
has a MapGuideApiEx.jar (with matching -sources.jar). Is there a way I can
obtain just that without having to go through a new install (since it is
bundled)? I currently have MG Open Source 2.2 installed and will not be able
to update now because we already have it deployed.
Do any of the API documentation examples : sheboygan and javasamples
actually contain java servlets? When i looked through all i saw was JSPs
(with embeded java code in them).
Since I am trying to use the MgFeatureService class  (to do the CRUD on SDF
data), I was under the impression i would have to use java servlets but in
the API examples I only see JSPs.
Sorry that some of my questions may be basic, i am trying to get my head
wrapped around some of the concepts.
-mapguidenoob
View this message in context: http://osgeo-org.1560.x6.nabble.com/reading-and-editing-SDF-data-with-java-tp5044300p5046484.html
