[mapguide-users] 64-bit woes
Jackie Ng jumpinjackie at gmail.com
Sun Apr 28 21:15:35 PDT 2013
Those dlls in question are not .net assemblies. I don't know why VS would try
to process them for metadata. Maybe because they're dlls in your output
directory. Either way it should not be an issue.
Local IIS debugging means that IIS will probably still have open handles on
your dlls from a previous VS debugging run hence the "sharing violation"
message. You'll have to recycle the associated application pool in IIS to
free these handles. Ugly solution, but there doesn't seem to be a better
way.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5050110.html
