[mapguide-users] Problem using Filter on Layer
Jérôme DUCKERS jerome.duckers at gmail.com
Fri Feb 1 00:36:39 PST 2013
Do you know FDO Toolbox ?
If not, you can take it,
1. Create a connection to your data (sdf/shp/oracle/ ... )
2. Make a Data Query
3. Insert you filter
4. See the result, is the contenido field the same ?
The data are in a SDF or SHP ? Can you send it ?
2013/2/1 naish666 <naish666 at msn.com>
> I have done it. It shows the same "contenido" for all points, but in the
> table, the column "contenido" is different for every registry. Why show the
> tooltip the same "contenido" for al points?
> If I left the filter field of the layer (in Maestro) it show all the points
> and different "contenido" for every point, but when I put the filter "tip=5
> OR tip=6 OR tip=7" it show the same "contenido" for every point.
> http://osgeo-org.1560.n6.nabble.com/Problem-using-Filter-on-Layer-tp5028966p5031433.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130201/099ee9e5/attachment.html>
