[mapguide-users] IMPORTANT - MapGuide RFC 136 is ready for review
Berg, James James.Berg at stantec.com
Tue Jun 18 04:34:48 PDT 2013
Thank you for the hotfix, Jackie. As a minor heads-up to those using these you might need to clear your application pool before overwriting the files otherwise the OS will demand that you close programs using the files.
I'm no expert on mapguide, but as someone who develops with mapguide I never saw the need to update SQL tables through the mapagent. My environment, asp.net, has plenty of tools for doing that.
