[mapguide-users] Fusion map layers
Jackie Ng jumpinjackie at gmail.com
Wed Mar 13 01:30:21 PDT 2013
The first call is to access the Map widget
The second call accesses a Fusion.Layers instance within the widget. If
you're not using any commercial layers, this array usually has a size of 1
and contains one Fusion.Layers.MapGuide instance.
This blog post I made should help explain it better:
http://themapguyde.blogspot.com.au/2013/02/mapguide-tidbits-maps-in-fusion.html
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-map-layers-tp5040050p5040062.html
