[mapguide-users] SetVisible from a BaseLayer or MgLayerGroupType=BaseMap
Hans Milling hm at geograf.dk
Tue May 7 00:29:59 PDT 2013
If you change the map in a code behind file, the browser/OpenLayers has no
knowledge that the map has changed. You need to make a refresh of the
layer/map in your javascript.
When you zoom, the map is refreshed and then you see your changes made in
the code behind.
Hans...
View this message in context: http://osgeo-org.1560.x6.nabble.com/SetVisible-from-a-BaseLayer-or-MgLayerGroupType-BaseMap-tp5051764p5051773.html
