[mapguide-users] QuickPlot problem in Fusion
dan.nilsson dan.nilsson at tyrens.se
Wed May 15 10:44:50 PDT 2013
I have installed MapGuide OS 2.5.0.7449 on a Windows 8 Enterprise x64 4GB
RAM.
I have imported a old mgp file to it and the Ajax viewer works fine. Also
QuickPlot in Ajax-viewer is working well. But I want to test Fusion viewer
and check how the speed is compared with Ajax. When I begin to test, I
activated the QuickPlot widget in Maestro ver. 4.0.4.7214. When I try the
map with turquoiseyellow in IE ver. 10.0.9200.16540 the map is working fine.
I click on the QuickPlot button in the toolbar, the quickplot dialog show up
in the task pane to the left. I don't change anything, just want to plot to
A4 Portrait Orientation. Click on the Generate button, a new window is
opening and I get this messege:
PHP Warning: fopen(C:/Program
Files/OSGeo/MapGuide/Web/www/fusion/lib/tcpdf/cache/img_52963dbb4e03a2abd2c661125d64bbfe)
[function.fopen]: failed to open stream: Permission denied in C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\lib\tcpdf\tcpdf.php on line 7553 PHP
Warning: fwrite() expects parameter 1 to be resource, boolean given in
C:\Program Files\OSGeo\MapGuide\Web\www\fusion\lib\tcpdf\tcpdf.php on line
7554 PHP Warning: fclose() expects parameter 1 to be resource, boolean given
in C:\Program Files\OSGeo\MapGuide\Web\www\fusion\lib\tcpdf\tcpdf.php on
line 7555 PHP Warning: unlink(C:/Program
[function.unlink]: No such file or directory in C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\lib\tcpdf\tcpdf.php on line 7560
What do I need to do to get it to work? As I can understand it has something
with permission to do, but I don't know where. Does anyone know what to do?
I have tried UAC set to Never Notify, but that doesn't help.
View this message in context: http://osgeo-org.1560.x6.nabble.com/QuickPlot-problem-in-Fusion-tp5053474.html
