[mapguide-users] QuickPlot problem in Fusion
dan.nilsson dan.nilsson at tyrens.se
Wed May 15 11:22:44 PDT 2013
So you mean that MapGuide should not be installed under Program Files, if I
want to use QuickPlot with PDF support?
Or can I change the path?
If so, in what file is that?
View this message in context: http://osgeo-org.1560.x6.nabble.com/QuickPlot-problem-in-Fusion-tp5053474p5053482.html
