[mapguide-users] How to use WMS with the Layer Map Definitions
Andrey Maraev asmaraev at gmail.com
Tue May 21 02:38:25 PDT 2013
Also I get the error in log file:
StackTrace:
  - MgMappingUtil.StylizeLayers() line 892 file
c:\mg-2.5-x64\mgdev\server\src\services\mapping\MappingUtil.cpp
<2013-05-21T12:29:04> 3808 Fusion Viewer ::1 Administrator
 Error: Failed to stylize layer: 250k_River
        The coordinate system initialization failed.
        Could not initialize the geodetic transformation.
How can I fix it?
Thanks in advance.
2013/5/21 Andrey Maraev <asmaraev at gmail.com>
> Mapguide OS 2.5.0
> Mapguide Maestro 4.0.4
> I just want to know may I use layers with styles together via WMS?
> 2013/5/21 Zac Spitzer <zac.spitzer at gmail.com>
>> alas WMS only supports layers at the moment....
>> which version of mapguide are you using
>> On Tue, May 21, 2013 at 12:27 AM, Andrey Maraev <asmaraev at gmail.com>wrote:
>>> Hello! I use Mapguide OS Server and have a mgp - package. After load the
>>> package via MG Site administrator I can see it in Mapguide Maestro Client.
>>> When I try to open WMS link
>>> http://localhost/mapguide/mapagent/mapagent.fcgi in qGIS I see the list
>>> of layers. How to get the map with the layer's group which has all styles?
>>> How to configure the WMS connector with using  EPSG:32648 and default WMS
>>> version 1.1.1?
>>> Thanx for your help!
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> +61 405 847 168
> lernen,lernen und lernen
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130521/0359a7fe/attachment.html>
