[mapguide-users] [MapGuide 2.4] Web .Net API SetResource failed 1 to 2 times
Rémy Gourrat rgourrat at ag-carto.fr
Fri May 31 00:29:47 PDT 2013
Thanks
But i saw when session expired in the log it’s “Session Expired…” not “Permission Denied…’
crazy
Rémy
De : zspitzer [via OSGeo.org] [mailto:ml-node+s1560n5057078h71 at n6.nabble.com]
Envoyé : vendredi 31 mai 2013 04:33
À : Rémy GOURRAT
Objet : Re: [MapGuide 2.4] Web .Net API SetResource failed 1 to 2 times
I'd guess the session expired?
On Thu, May 30, 2013 at 9:22 PM, Rémy Gourrat <[hidden email]</user/SendEmail.jtp?type=node&node=5057078&i=0>> wrote:
Hello,
I have a .net web api  wich edit feature source definition
At the end of the function, I update the new feature source definition by this code in the session repository
// Chargement du String xml dans une variable type MgByteSource
                               MgByteSource contentByteSource = new MgByteSource(encodedDefinition, encodedDefinition.Length);
                               //Ecriture du nouveau FeatureSourceID dans la Session: en lieu et place du précédent s'appuyant sur Library
                               String str_NewFeatureSourceId = FeatureSourceListElem.Replace("Library:","Session:" + sessionId);
                               MgResourceIdentifier new_MgfeatureSourceId = new MgResourceIdentifier(str_NewFeatureSourceId);
                               // Sauvegarde de la ressource avec la nouvelle définition
                               ag_ResourceService.SetResource(new_MgfeatureSourceId, contentByteSource.GetReader(), null);
During many hours it’s running very very  well
And suddenly it’s failing, and after few minutes or hours or enable the iis trace it’s running well again !
But when it failed, my Exception Catch code is not executing in my function
                catch (MgException mge)
                               errMsg = mge.GetExceptionMessage() + "\n" + mge.GetDetails();
                               ag_PrintMessage("ag_proc.aspx : " +  "ag_SetSRSFeatureSource : ","Erreur ! Exception levée par Catch " + errMsg);
But I have a message in the Errors.log :
<2013-04-26T12:12:16>                2084                                      Anonymous
 Error: Permission denied to resource: Session:c3b53a1a-ae59-11e2-8000-00155d2d5706_en_MTI3LjAuMC4x0AFC0AFB0AFA//Ag Base/2 - Calques/ASSC_LDE/LDE_A_COLLEC_EP.LayerDefinition
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation() line 80 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
  - MgOpSetResource.Execute() line 103 file c:\mg-2.4-x64\mgdev\server\src\services\resource\OpSetResource.cpp
  - MgServerResourceService.SetResource() line 1064 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgRepositoryManager.SetResource() line 563 file c:\mg-2.4-x64\mgdev\server\src\services\resource\RepositoryManager.cpp
  - MgRepositoryManager.AddResource() line 536 file c:\mg-2.4-x64\mgdev\server\src\services\resource\RepositoryManager.cpp
  - MgResourceContentManager.AddResource() line 183 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
  - MgResourceContentManager.PutDocument() line 624 file c:\mg-2.4-x64\mgdev\server\src\services\resource\ResourceContentManager.cpp
  - MgSessionRepositoryManager.CheckPermission() line 238 file c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp
  - MgSessionResourceContentManager.CheckPermission() line 235 file c:\mg-2.4-x64\mgdev\server\src\services\resource\SessionResourceContentManager.cpp“
Somebody have an explanation for this ? is there a specific concept that I don’t understand ?
Thanks
Rémy
AG-Carto - Bayonne
View this message in context: [MapGuide 2.4] Web .Net API SetResource failed 1 to 2 times<http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-Web-Net-API-SetResource-failed-1-to-2-times-tp5056933.html>
Sent from the MapGuide Users mailing list archive<http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html> at Nabble.com.
mapguide-users mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5057078&i=1>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
[hidden email]</user/SendEmail.jtp?type=node&node=5057078&i=2>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-Web-Net-API-SetResource-failed-1-to-2-times-tp5056933p5057078.html
To start a new topic under MapGuide Users, email ml-node+s1560n4182607h70 at n6.nabble.com<mailto:ml-node+s1560n4182607h70 at n6.nabble.com>
To unsubscribe from MapGuide Users, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4182607&code=cmdvdXJyYXRAYWctY2FydG8uZnJ8NDE4MjYwN3w1MzYwNTE3NDA=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-2-4-Web-Net-API-SetResource-failed-1-to-2-times-tp5056933p5057109.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130531/7832d134/attachment.html>
