[mapguide-users] Help - Resource Id with space character
Jag jaugusto at phinformatica.pt
Wed Oct 9 06:04:08 PDT 2013
Thank you very much for the reply but, read the initial post, please.
I already tried that:
"/Using the url:
http://localhost:8008/mapguide/mapagent/index.html
 and executing the EnumerateResources I can't the the resource in the
results but in view Source I see the correct XML.
Executing ResourceExists with the space in the name I get false, without the
space I get true.
But when I try DeleteResource, I get an exception:
An exception occurred in DB XML component. Error: Document not found:
Library://Mapas/MapaGoogle.MapDefinition
Using the space in the name I get a blank page and the resource is still
there./"
Is it possible to change the resource name in some file?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-Resource-Id-with-space-character-tp5082396p5082616.html
