[mapguide-users] Problems with spatial select on MSSQL based layer
Jackie Ng jumpinjackie at gmail.com
Thu Sep 5 23:35:57 PDT 2013
Check your spatial indexes and the area they cover (ie. Not covering the
whole planet).
Use RDBMS provider trace logging
(http://themapguyde.blogspot.com.au/2013/01/mapguide-tidbits-fdo-rdbms-provider.html)
to see what SQL is being executed and combine it with your query
analysis/planning tools in SQL Server to see where it is bottlenecking.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-spatial-select-on-MSSQL-based-layer-tp5076371p5076375.html
