[mapguide-users] Mapguide vs OpenLayers: troubles with tiles on EPSG 21781
Franz1965 fsozzi at INTERCAD.CH
Sat Feb 1 16:43:49 PST 2014
Hi everybody,
I have no problem with OpenLayers sample on Mapguide if I execute on
Sheboygan, bot tiled and not tiled.
I have no problems if I convert this sample on my project on EPSG:21781 on
not-tiled version.
But tiled map does not display. I can display tiled map on AjaxViewer or
Maestro, but not on OpenLayers.
Any idea?...
Best regards
//tiled version
function initTiled(){
	var extent = new
OpenLayers.Bounds(562985.576,158127.222,568066.399,165643.041);
	var tempScales = [35000,15000,5000,1500,500,200,100];
	var mapOptions = {
		maxExtent: extent,
		scales: tempScales
	map = new OpenLayers.Map( 'map', mapOptions );
	var params = {
	  mapdefinition: 'Library://INFOGEO/MyProject/Default.MapDefinition',
	  basemaplayergroupname: "Base Layer Group"
	var options = {
	  singleTile: false
	var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS tiled layer", url,
params, options );
	map.addLayer(layer);
	map.zoomToMaxExtent();
//un-tiled version
function initUntiled() {
  var extent = new
  var mapOptions = {
		units: 'm',
		projection: 'EPSG:21781',
		maxExtent: extent,
		maxResolution: 'auto',
		controls: []
  map = new OpenLayers.Map( 'map2', mapOptions );
	map.addControl(new OpenLayers.Control.NavToolbar());
	map.addControl(new OpenLayers.Control.PanZoom());
	map.addControl(new OpenLayers.Control.NavigationHistory());
  var options = {
	  isBaseLayer: true,
	  transitionEffect: "resize",
	  buffer: 1,
	  useOverlay: false,
	  useAsyncOverlay: false,
	  singleTile: true
  var params = {
  var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS untiled
baselayer", url, params, options );
	map.addControl(new OpenLayers.Control.LayerSwitcher());
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-vs-OpenLayers-troubles-with-tiles-on-EPSG-21781-tp5101387.html
