[mapguide-users] How to change the initial task pane URL programatically
Flipper scotth at mpowerinnovations.com
Wed Feb 12 14:09:03 PST 2014
Not in front of code but thought we just referenced
top.parent.getelementbyid and everything worked fine between the two
frames/divs
On Feb 12, 2014 12:04 PM, "Liglio [via OSGeo.org]" <
ml-node+s1560n5103450h37 at n6.nabble.com> wrote:
> Flipper,
> you will have the 2 domains problem. My application is http://host/GisWeb and
> the iframe where fusion is called http://host/mapguide. Two differents
> applications web sites in IIS (GisWeb and mapguide) are considered
> differents domains. Have you tryied ?
> Why your TaskPane must be outside Fusion frame ? This layout doesn´t suit
> you ?
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/How-to-change-the-initial-task-pane-URL-programatically-tp5102583p5103450.html
>  To unsubscribe from How to change the initial task pane URL
> programatically, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5102583&code=c2NvdHRoQG1wb3dlcmlubm92YXRpb25zLmNvbXw1MTAyNTgzfDMyMzM0MDY4Mg==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-change-the-initial-task-pane-URL-programatically-tp5102583p5103476.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140212/cc84b5ae/attachment.html>
