[mapguide-users] map guide 4j set up
Smith Roman autisi at yahoo.com
Sat Jan 4 11:28:55 PST 2014
I decided to use play 2.0.4 framework as specified in the url. I am now getting the following error
C:\play\play-2.0.4\samples\java\mapguide4j-master>play run
sbt appears to be exiting abnormally.
  The log file for this session is at C:\Users\ROMAN\AppData\Local\Temp\sbt17696
20787851343004.log
java.lang.NoClassDefFoundError: sbt/AbstractLogger
        at sbt.Keys$.<init>(Keys.scala:32)
        at sbt.Keys$.<clinit>(Keys.scala)
        at sbt.MainLoop$$anonfun$runWithNewLog$1.apply(Main.scala:102)
        at sbt.MainLoop$$anonfun$runWithNewLog$1.apply(Main.scala:100)
        at sbt.Using.apply(Using.scala:25)
        at sbt.MainLoop$.runWithNewLog(Main.scala:100)
        at sbt.MainLoop$.runAndClearLast(Main.scala:83)
        at sbt.MainLoop$.runLoggedLoop(Main.scala:67)
        at sbt.MainLoop$.runLogged(Main.scala:60)
        at sbt.xMain.run(Main.scala:33)
        at xsbt.boot.Launch$.run(Launch.scala:54)
        at xsbt.boot.Launch$$anonfun$explicit$1.apply(Launch.scala:43)
        at xsbt.boot.Launch$.launch(Launch.scala:68)
        at xsbt.boot.Launch$.apply(Launch.scala:14)
        at xsbt.boot.Boot$.runImpl(Boot.scala:25)
        at xsbt.boot.Boot$.main(Boot.scala:15)
        at xsbt.boot.Boot.main(Boot.scala)
Caused by: java.lang.ClassNotFoundException: sbt.AbstractLogger
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        ... 17 more
Error during sbt execution: java.lang.NoClassDefFoundError: sbt/AbstractLogger
Any ideas ?
Regards,
Smith
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140104/e145c9d5/attachment.html>
