[mapguide-users] MapGuide Maestro6.0a3 and Raster.
Berg, James James.Berg at stantec.com
Fri Jul 18 06:41:36 PDT 2014
What dlls you need will depend on which version of MapGuide OS you have because different versions use different version of FDO. Version 2.4 and 2.5 use FDO 3.8, I believe, and the newest 2.6 uses FDO 3.9.
What version of MapGuide are you using?
You also need different dlls depending on if you use the 32 or 64 bit version of MapGuide (the version of Maestro doesn’t enter into it.) You also need to add the dlls to specific folders in your MapGuide installation. Like I mentioned, all of this will require some research. I recommend searching this mailing list and highly recommend using dependency walker to avoid drowning in missing dll hell.
If you’re using 2.4 or 2.5, here’s a tutorial I wrote to remind myself how to install Mr Sid support. Remember, you’ll need different dlls depending on your MapGuide version and bitness.
This web page describes how to install the plugin on MGOS 2.2. Do not use the dlls listed here; they are out of date. It provides a list of where the plugins should go which is useful.
http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
This web page is from the MapGuide Users mailing list. It describes how to install the ECW plugin for GDAL. It shows where to find the plugins and where they should go. The dlls needed for ECW are simliar to Mr Sid so the steps apply.
http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-td4995445.html#a4995528
The dll files can be downloaded here as indicated in the web page above. Download the first file. These are the right files assuming you version of MGOS is still on a 32bit OS uses GDAL ver 1.9.
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-gdal-1-9-0-mapserver-6-0-1.zip
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20140718/16a2ebcb/attachment.html>
