[mapguide-users] QUERYMAPFEATURES and requestdata = 3 throws NpE
mjirku martinjirku at gmail.com
Mon Jun 16 21:00:35 PDT 2014
Hi Flipper,
I am little bit confused, what do you mean by real world unit?
Original data in database (MS SQL) are in JTSK.
Working mapdefinition (mapdefinition which returns bounds) uses:
PROJCS["CzechJTSK/5.Krovak",GEOGCS["CzechJTSK/5.LL",DATUM["CzechJTSK/5",SPHEROID["BESSEL",6377397.155,299.15281535]],PRIMEM["Ferro",
-17.6666666666667],UNIT["Degree",0.017453292519943295]],PROJECTION["Krovak"],PARAMETER["longitude_of_center",42.50000000000000],PARAMETER["latitude_of_center",49.50000000000000],PARAMETER["azimuth",30.28813975989891],PARAMETER["pseudo_standard_parallel_1",78.50000000000000],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999900000000],UNIT["Meter",1.00000000000000]]
While I need for my custom client side application WGS84 pseud., I am using
in mapdefinition coordinate system defined as:
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
Should I change something to make it work?
View this message in context: http://osgeo-org.1560.x6.nabble.com/QUERYMAPFEATURES-and-requestdata-3-throws-NpE-tp5145379p5146205.html
