[mapguide-users] Postgis views not selectable when using join
isca mapguide2007 at gmail.com
Fri May 9 01:36:43 PDT 2014
Hello,
I am having following configuration:
- MGOS 2.5.1
- Postgresql 9.3/Postgis 2.1
- Windows 2008
When creating a layer on a database view which is based on one table we can
make a selection without any problems. If we make a view that is based on
multiple tables (join) it is not possible anymore to select objects in the
layer. Is this a known issue and are there any workarounds ? I know there is
the possibility to override the schema, but I prefer not to do this as we
would loose flexibility in this case (database changes).
View this message in context: http://osgeo-org.1560.x6.nabble.com/Postgis-views-not-selectable-when-using-join-tp5139362.html
