[mapguide-users] MapGuide Open Source 3.0 test build for 64-bit Linux
scoobylx brandon.mason at maritimearchaeology.co.uk
Thu Oct 16 01:44:45 PDT 2014
Quick response: I have mapguide 3.0 x64 running in a CentOS docker container
using Jackie's modified docker file. First impressions are that it seems
subjectively quicker, all my packages have loaded successfully and I can see
my maps loading fine.
Couple of errors that probably relate to providers: no raster images are
loading and I'm getting a 'fusion object' error and no data loading on a
flexible layout, but this is all using postgis data.
External map providers are all working fine.
Jackie, can you point me towards downloading and loading the
GDAL/postgres/posgis providers for x64 please? Exciting stuff...
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-3-0-test-build-for-64-bit-Linux-tp5167443p5167775.html
