[mapguide-users] php - edit map in repository, save modifications back
Rémy GOURRAT rgourrat at ag-carto.fr
Fri Oct 17 06:25:59 PDT 2014
Hi Rob,
I'm not a great developper, but i understood with few bad experiences that with MapGuide  API you can only save new resource in Session Repository not in the Library of your hard disk.
You just have 3 ways :
- use Maestro/Studio to add manually the layer in yours maps
- Do a runtime map by php or asp .net and add the layer dynamically in your maps each time a user uses the map
- Use Python in Maestro to add the layer in many maps in one time
Good luck
Rémy
