[mapguide-users] sql filters on map load
Mark Volz (LeapCAD) mark at leap-cad.com
Fri Oct 31 16:05:51 PDT 2014
Further to Gordon's response, if you look at
http://localhost/mapguide/help/devguide/index.html (on the server that you
have installed MapGuide OS on) and go to the section called "modifying maps
and layers" you will see some examples and a work through of what the code
is doing.
Mark
