[mapguide-users] MGOS release 3.0 and Commercial maps
pcardinal pierre.cardinal at sympatico.ca
Thu Aug 27 16:29:24 PDT 2015
*MGOS 3.0 is "buggy" with commercial maps. Everything was OK with MGOS2.6 but
with MGOS 3.0 it is impossible to use commercial maps.
*-------------------------------------------Fusion ErrorErrorError
Details:Exception occurred in AJAX callback.Message: Caractère
incorrectLocation: undefined (undefined)Inner Stack: SyntaxError: Caractère
incorrect   at window.Fusion.parseJSON
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:33:328)   at
parseMapTip
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:3096:467)   at
Anonymous function
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:1171:465)   at
respondToReadyState
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:2057:587)   at
onStateChange
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:2055:421)   at
Anonymous function
(http://localhost/mapguide/fusion/lib/fusionSF-compressed.js:1171:465)Response:
Invalid argument(s):The map display width cannot be less than or equal to
zero.Invalid argument(s):The map display width cannot be less than or equal
to zero.- MgRenderingServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp-
MgOpQueryFeatures.Execute() line 125 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp-
MgServerRenderingService.QueryFeatures() line 1092 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp-
MgServerRenderingService.RenderForSelection() line 1459 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\rendering\ServerRenderingService.cppStack
Trace: - ? at http://localhost/mapguide/fusion/lib/fusionSF-compressed.js
(line: 54) - window.Fusion.parseJSON at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 33) -
parseMapTip at http://localhost/mapguide/fusion/lib/fusionSF-compressed.js
(line: 3096) - respondToReadyState at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 2057) -
onStateChange at http://localhost/mapguide/fusion/lib/fusionSF-compressed.js
(line: 2055) - window.Fusion.ajaxException at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 32) -
dispatchException at
http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line: 2058) -
(line: 2055)Source:
http://localhost/mapguide/fusion/templates/mapguide/slate/index.html?Session=3853ae2a-4d0d-11e5-8000-90b11c9f31d3_en_MTI3LjAuMC4x0AFC0AFB0AFA&ApplicationDefinition=Session:3853ae2a-4d0d-11e5-8000-90b11c9f31d3_en_MTI3LjAuMC4x0AFC0AFB0AFA//0a2938f0-b617-49a3-bea1-509e224950d9.ApplicationDefinition&locale=en------------------------------------MapDefinition<?xml
version="1.0"?>
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
-8237000    -8174000    5678000    5737700    ffffffff
<MapDescription>test</MapDescription>
---------------------------------------------------------------------------ApplicationDefinition
Slate  fusion/templates/mapguide/slate/index.html
MapGuide        True                  Library://Test/testMap.MapDefinition
false            true            EPSG:900913
VirtualEarth        true                              Bing Maps Street
Road                                          Toolbar      Toolbar....
View this message in context: http://osgeo-org.1560.x6.nabble.com/MGOS-release-3-0-and-Commercial-maps-tp5221558.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150827/3b32f05b/attachment.html>
