[mapguide-users] Error using quickplot - TCPDF ERROR: [Image] Unable to get image:
Jackie Ng jumpinjackie at gmail.com
Fri Feb 6 03:43:04 PST 2015
If this is consistently reproducible, what happens if you save that
GeneratePicture.php as an image, serve it as a static image file from the
same web server and as a test modify PlotAsPDF.php to replace the
GeneratePicture.php url with a url to your saved image, does TCPDF still
throw the error when pointing to the static image?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-using-quickplot-TCPDF-ERROR-Image-Unable-to-get-image-tp5185933p5185947.html
