[mapguide-users] MapGuide/Maestro IF function not recognised in Tooltip or Hyperlink expression editor
Rémy Gourrat rgourrat at ag-carto.fr
Mon Jan 5 07:06:39 PST 2015
i think it miss a right parenthesis in your expression and I think you must quote your expression like this,
I validate this with MapGuide 2.5.2
IF('NOT LIBELLE2 NULL',CONCAT (LIBELLE1, LIBELLE2),'Nothing') )
Rémy
De : lucvanlinden [via OSGeo.org] [mailto:ml-node+s1560n5180026h59 at n6.nabble.com]
Envoyé : lundi 5 janvier 2015 15:08
À : Rémy GOURRAT
Objet : MapGuide/Maestro IF function not recognised in Tooltip or Hyperlink expression editor
Hi
I wanted to evaluate a property for its null value. If not NULL then set a hyperlink using that value.
In the Maestro expression editor, the IF function can be used. However this is not recognized by mapguide and read literally.
for example
IF (myproperty NULL, 'Nothing', Concat('mylink', myproperty)
is not evaluated but used as
"IF (myproperty NULL, 'Nothing', Concat('mylink', myproperty)" .
Is there a way to conditionally set these properties?
Maybe in the resource XML itself?
tx
Luc
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-IF-function-not-recognised-in-Tooltip-or-Hyperlink-expression-editor-tp5180026.html
To start a new topic under MapGuide Users, email ml-node+s1560n4182607h70 at n6.nabble.com<mailto:ml-node+s1560n4182607h70 at n6.nabble.com>
To unsubscribe from MapGuide Users, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4182607&code=cmdvdXJyYXRAYWctY2FydG8uZnJ8NDE4MjYwN3w1MzYwNTE3NDA=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
This message has been scanned for viruses and
dangerous content by MailScanner<http://www.mailscanner.info/>, and is
believed to be clean.
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-IF-function-not-recognised-in-Tooltip-or-Hyperlink-expression-editor-tp5180026p5180045.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150105/465e0556/attachment.html>
