[mapguide-users] MapGuide 2.5.2 : runtime map not properly closed...
Riccardo Pucci riccardo.pucci at geowebitalia.it
Wed Jan 14 02:34:40 PST 2015
The only thing I found should be explicitly closed is FeatureReader...
Riccardo
2015-01-13 19:29 GMT+01:00 Rémy Gourrat <rgourrat at ag-carto.fr>:
>  Hi,
> I developped in .net, a mapguide 2.5.2 ajax viewer application which read
> a map definition in library repository, edit and change the srs of all the
> feature source used by the current map,  add a filter to each layer and
> save it in the repository session.
> It seem to work fine.
> But 1 time by day, after 20 or 30 session initialized, mapguide can’t
> initialize a new session.
> The Old sessions are fine, I checkrd serverconfig.ini but I didn’t change
> the limit session.
> If i do nothing, sometime or not I have a dbxml error in the log but not
> systematically : “Error: An exception occurred in DB XML component.”
> But i see something important,
> - if i use a map without using my code (standard solution), after closing
> the viewer, MapGuide close the session and delete session files in the
> session repository correctly.
> - if I use the same map but using my code, map display and run very fine,
> but MapGuide never close the session.
> Session files in the session repository are present until I restart the
> mapguide service.
> If I try to connect to this session with Ajax viewer it said to me this
> session not exist…
> It’s a bug.
> i think I must forget something fundamental,
> is it necessary to close resource and feature service after generation of
> the runtimemap, and how ?
> is it something locked and mapguide can’t really delete sessions files ?
> thanks for your help
> Rémy
>  AG-Carto - Bayonne
> View this message in context: MapGuide 2.5.2 : runtime map not properly
> closed...
> <http://osgeo-org.1560.x6.nabble.com/MapGuide-2-5-2-runtime-map-not-properly-closed-tp5181326.html>
> Sent from the MapGuide Users mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html> at
> Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Riccardo Pucci
Geoweb Italia S.r.l.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150114/aa2e12c6/attachment.html>
