[mapguide-users] Initial map unit in degrees
Liglio liglio at pobox.com
Mon Jan 26 08:52:40 PST 2015
Gordon,
Yes It works using the interface to change the map unit to degrees. The
problem is when I set the ApplicationDefinition.xml to use degrres as
default. It does not work. Did it work in your environment, setting the
ApplicationDefinition.xml to degrees ?
     <Extension xsi:type="CustomContentType">
        <DisplayUnits>degrees</DisplayUnits>
      </Extension>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Initial-map-unit-in-degrees-tp5183224p5183793.html
