[mapguide-users] Improving AIMS/Mapguide bundled PHP performance
Jackie Ng jumpinjackie at gmail.com
Thu Nov 5 16:34:16 PST 2015
I think the PHP 5.3.8 is not the official windows build (due to MSVC version
differences). Maybe this version mismatch is what's causing PHP to blow up.
As for testing, most performance tests follow the same formula do they not?
 1. Run $SUBJECT_UNDER_TEST for $ITERATIONS
 2. Run $SUBJECT_UNDER_TEST for $ITERATIONS with the performance
improvements active.
 3. Compare numbers from 1 and 2.
Also YMMV. I saw objective improvements in mapguide-rest execution speed
with opcode caching enabled. Other PHP applications may not stand to benefit
as much.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Improving-AIMS-Mapguide-bundled-PHP-performance-tp5234550p5234782.html
