[mapguide-users] Using an external WMS in MapGuide Maestro
Jackie Ng jumpinjackie at gmail.com
Tue Nov 17 07:25:49 PST 2015
Feature Source preview is mainly for Vector Feature Sources. It is almost
always useless for raster-based ones like WMS.
What you should almost always do when creating a WMS feature source, is
create a configuration document for it. You might have noticed a warning
sign blinking beside the "Advanced" button in the WMS feature source editor
when you first created it. Click it and a default configuration document
will be built, which is saved into the Feature Source when you click "Save"
in the following dialog.
>From there, save the feature source itself. Then make a Raster Layer
Definition that points to this Feature Source and you should be able to
preview it.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-an-external-WMS-in-MapGuide-Maestro-tp5235696p5236906.html
