[mapguide-users] Shapefile with 200+ fields
Jackie Ng jumpinjackie at gmail.com
Thu Aug 25 18:21:46 PDT 2016
If you can't change/convert the SHP file (200+ fields? Really?) and the file
is read-only, perhaps you could try using an OGR provider connection to a
VRT file (http://www.gdal.org/drv_vrt.html) pointing to the SHP file and in
the VRT file, only select out the columns/properties of interest. That
property list should then reflect in any class definition we get from the
OGR feature source.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Shapefile-with-200-fields-tp5282394p5282400.html
