[mapguide-users] Mapagent error with blank image
lbressan leonardo.bressan at abitat.it
Fri Jan 8 07:22:56 PST 2016
The only error message We receive is this (we use the "Web Tier Test")
http://mapguideip:mapguideport/mapguide/mapagent/mapagent.fcgi?OPERATION=GETSITESTATUS&VERSION=2.2.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer
<html>
<head>
<title>MgUnclassifiedException</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
</head>
<body>
Problem:\nThe application encountered a problem and could not finish the
operation you just requested
 properly.\n\nSolution:\nIf it\'s the first time you met this problem, try
again or restart the application
 / session; otherwise, describe the steps to reproduce this problem to the
server administrator for suggestions
- ApacheAgent.mgmapagent_handler() line 237 file ApacheAgent.cpp
- MgConfiguration.GetBoolValue() line 250 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\common
\foundation\System/Configuration.cpp
- MgConfiguration.GetValue() line 375 file
c:\working\build_area\mapguide\2.6.1\x64\mgdev\common\foundation
</body>
</html>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapagent-error-with-blank-image-tp5244292p5244306.html
