[mapguide-users] Map Guide Open Source 3.0 on HTML 5 on Desktops and Devices
Shashank Vittal shashank.vittal87 at gmail.com
Mon Jul 11 20:27:10 PDT 2016
Hi There,
I am working on migrating an replacing Autodesk Mapguide 6.5 to Map guide
open source 3.0.
I am quite certain that Map Guide Open Source 3.0 is compatible on HTML 5
supported browsers on Desktops and Devices (Samsung tabs and S7).
Just wanted to check if somebody has actually tested this out.
Also, the current Autodesk Mapguide 6.5 generated Maps from SQLLite files.
I am assuming that this will hold good for Map Guide Open Source as well ?
Thanks,
Shashank
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20160712/ff8d9bba/attachment.html>
