[mapguide-users] WFS and the King Oracle FDO provider
Philip Nell pnell at openspatial.com
Wed May 4 16:03:45 PDT 2016
Thanks for looking into this Jackie.
So the guys at http://www.sl-king.com might have to look at it at the Oracle provider level at some point in the future.
We continue to use the KingFdoClass table described here:  http://www.sl-king.com/fdooracle/KingFdoClass.htm
Cheers
Philip Nell
Geospatial Solutions Architect
Open Spatial | Tel: +61 2 9904 7077 | Mobile: +61 404 093 925
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, 4 May, 2016 10:49 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] WFS and the King Oracle FDO provider
Just an update on this.
I'm not going to make the planned fix of scrubbing out '~' characters in the WFS response as this will most likely break how WFS clients are meant to
work:
 1. Request a WFS capabilities document
 2. Pick a WFS [encoded layer name]
 3. GetFeatures with the WFS [encoded layer name]  4. Process the GetFeatures response using the [encoded layer name] to determine how to extract the feature data whose elements will be named [encoded layer name]
The fix I had would've addressed step 4, but would break steps 1-3 as WFS would've still advertised the layer name with '~' and you would've still needed the layer name with '~' to make the GetFeatures request, and if we scrubbed the element name as per my planned fix it would break client behaviour on how to handle step 4.
Scrubbing the '~' in the GetCapabilities response in step 1 is not an option either, because at some point, we have to reverse translate that scrubbed layer name back to the FDO class name, so that the FDO queries will still work and there is no MapGuide-level configuration point currently that allows us to define such class name mappings so we can forward and reverse translate between FDO class names and WFS encoded layer names. This is primarily something FDO providers provide (excuse the pun) through the configuration document mechanism, or in the case of the King.Oracle provider, the KingFdoClass special table.
So long story short, '~' was a *very poor* choice of delimiting character used by the King.Oracle FDO provider that we currently can't workaround at the MapGuide-level. Use the KingFdoClass mechanism to provide "clean" class names that won't break WFS responses.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-and-the-King-Oracle-FDO-provider-tp5256626p5264530.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
