[mapguide-users] Editing DWG with MapGuide Open Source?
GordonL gordon.luckett at arrowgeomatics.com
Wed May 11 15:03:13 PDT 2016
True, even if you have AIMS you might have trouble.
I have tried using mapguide-rest to edit the DWG and regardless of the
MapGuide setting (READONLY=false)
I still get readonly properties in the DWG
For example, I want to change the layer from Parcels to Zoning and I get the
following JSON error from MapGuide-Rest...
"Cannot set or modify readonly property: 'layer'   (Cause: , Root Cause:
Cannot set or modify readonly property: 'layer'"
Even the file is flagged as editable...
gordon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Editing-DWG-with-MapGuide-Open-Source-tp5265215p5265899.html
