[mapguide-users] How to use ActivityIndicator fusion widget
GeorgesK georges.kacou at gmail.com
Tue May 17 03:22:17 PDT 2016
I am reposting my message due to viewing problems with the "raw" tags in
nabble :
Thanks Jackie for the response.
I use the Aqua fusion template. Here is what  did :
* I modified the index.html file by addind the div (ID = "Loading") this way
<div id="AppContainer" style="visibility: hidden;">
  <div id="Map">
    <div id="Navigator"></div>
    <div id="Loading"
style="display:flex;justify-content:center;align-items:center;width:100%;height:100%;">
      <div>Loading ...</div>
    </div>
  </div>
  <div id="FileMenu"></div>
  <div id="Toolbar">
  </div>
  <div id="ToolbarVertical">
  </div>
  <div id="StatusbarContainer">
    <div id="Statusbar"></div>
    <div id="StatusOverviewMap"></div>
    <div id="pbmg"> <images/pbmg.gif> </div>
  </div>
  <div id="Maptip"></div>
</div>
* I inserted the ActivityIndicator widget in the vertical toolbar with this
XML
<?xml version="1.0" encoding="utf-8"?>
<WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <Name>Indicator</Name>
  <Type>ActivityIndicator</Type>
  <Location />
  <Extension>
    <ElementId>Loading</ElementId>
  </Extension>
</WidgetType>
Unfortunately, it still doesn't work and fusion throws an error. What is
weird is that the error message varies depending on the browser :
- With Firefox:
Error Details:
TypeError: this.domObj is null
Stack Trace:
 - ? at http://localhost/mapguide/fusion/lib/fusionSF-compressed.js (line:
2617)
- With Chrome and Internet Explorer:
Error Details:
Uncaught TypeError: Cannot read property 'appendChild' of null
Stack Trace:
2617)
What am I doing wrong ?
Thanks again.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-ActivityIndicator-fusion-widget-tp5265788p5266764.html
