[mapguide-users] Out of Order SelectionPanel.js?
Jackie Ng jumpinjackie at gmail.com
Thu Oct 6 05:59:33 PDT 2016
I see 2 problems here:
 - Maestro bug: What you see in the display properties in the Layer
Definition *is not what you get* order-wise.
 - QUERYMAPFEATURES is not respecting the display order in the Layer
Definition
I've made 2 tickets for this:
 - https://trac.osgeo.org/mapguide/ticket/2746
 - https://trac.osgeo.org/mapguide/ticket/2747
In terms of priority, the QUERYMAPFEATURES one is the higher priority one
that I will try to fix before 3.1 final as the Maestro one can be worked
around by hand-editing the XML.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Out-of-Order-SelectionPanel-js-tp5288902p5289621.html
