[mapguide-users] Introducing mapguide-react-layout: A modern viewer for MapGuide
morkl mapguide at morkl.se
Tue Oct 11 03:16:54 PDT 2016
The requested image size to viewport size ratio is explicitly set to 2:
https://github.com/jumpinjackie/mapguide-react-layout/blob/827358d6aa5fbb4313d6d90d33f3655507dcb492/src/components/map-viewer-base.tsx#L763
https://github.com/jumpinjackie/mapguide-react-layout/blob/827358d6aa5fbb4313d6d90d33f3655507dcb492/src/components/map-viewer-base.tsx#L775
Setting it to 1 should make it request the same image size as the viewport?
Alternatively, to allow large requests with normal quality WMS layers,
increase these values in serverconfig.ini:
MaxRasterImageHeight = 2048
MaxRasterImageWidth = 2048
However, this only works if the WMS server also allows large requests.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Introducing-mapguide-react-layout-A-modern-viewer-for-MapGuide-tp5288019p5290177.html
